what problems exactly?
In one network u have only to use one conf type
that is fine and theoriticaly valid
Otherwise intersubframe inter site with diiferent conf will occur
That I know. Do you have any case study or report?
No. Case study no. One question
Did you notice KpI or customer experience issues after changing config?
Will u modify in all the network??
yes. we have small network and mostly the downlink is congested…uplink is free
R u sure that software support type 4 and 5
4 it doesn’t. 5 is supported as per Hedex.
we will be upgrading to eRAN11.1 soon. which config r u using currently?
Sa2 for one customer. And sa1 for an other one.
Which country ??
so ur uplink traffic is too much? config 1
es for btob users
2:2 ratio of UL: DL
Yes. That is correct.
we have fixed broadband network not mobile
Yes for us also…Wttx sol
So u never implemented any other config than 1 and 2?
No never implemented
