Boda Lite - Multivendor/Multitechnologies Network Management Tool (CM, PM and more)
That’s awesome software honestly, it does an excellent job in many ways and can replace OMStar in certain functions. I have one comment regarding MML commands exporting, when I try to export them “combined” they kinda look messy (but totally awesome separately).
Another question: does accept LTE “CFGMML”?
This is awesome Soft from the Expert who knows how and will be…thank you so much…
Hi I downloaded, BODA but unable to parse xml, while trying to input xml file, its showing as empty
Great work!
how to get Huawei PM files as XML to be input here? as normal path “/bam/common/MeasResult” gets MRF.GZ file type.
Hi Vishal , Just give path to the folder where you have placed Input file and give output directory details .
Note:- Input and Output directory should be different
It was really a nice tool (and the latest available version continues to be).
Thanks @Emmanuel for all the efforts, and i understand why yu had to stop.
We all (community) loose, but at same time we understand your point - and without collaboration no project can survive. :frowning:
Can anyone help me with the below issue in red, it appears whenever i try to parse files.
Great tools ! You lead the community !
dear Asep,
i did change the directory but still get empty on the out put folder
dear sumit,
i did change the directory but still empty on the output folder
Hello, does Boda support parsing of Ericsson CTUM files?
Hello,
Does Boda support database anymore?
Hi,
Boda lite doesn’t parse Huawei R21 version properly. Many files are missing while Cfgmml parsing.
How to use HLOOKUP in excel
How to use HLOOKUP in excel - YouTube
How to use VLOOKUP Single in excel
How to use VLOOKUP Single in excel - YouTube
How to use VLOOKUP Multiple in excel
How to use VLOOKUP Multiple in excel - YouTube
How to autofill values in below blank cells using excel
How to autofill values in below blank cells using excel - YouTube
@squaresimple are you able to share a sample (privately) so we cn investigate this
1.Installed successfully but the username and password didnot match
3.Applied the password as per this document
Can any one guide me what could be the username and password? or what could be the reason? @Emmanuel
This parser is not working with OpenJDK 17.0
My company recently uninstalled Oracle Java 17 and rolled out OpnJDK 17.0
Since then parser has stopped working.
Kindly support to resolve the issue
thanks a lot
Hello! Thank you very much from ET!
