It is password protected? But you can extract it!
Yes all pre defined scripts are password protected… Have tried it but it’s not extracting. Sorry
Can you open it through script builder…and send a screenshot
hi bro,
did you have the zip file of script builder?
bro, do you have the script for this?
Dear,
How can I create a script to display log files name as you made on above plots??
Dear,
Can you please share C# code for this script
Please share C# code for this script
Could you show me the code for that file tab?
any updates ?
can you please tell me what is the source data i have to use for alias…
i can’t save the code without an Alais, it gives a message like this, i am new in scripting, please help on it.
just take a random metric and use put it with an alias.
You don’t need to use the alias in the script at all.
Thanks a lot, i worked but as i got another script (protected, can’t see script), for same log file it provide more sample. Is there any way to control it.
You can use the static option in metric and that will provide more “samples” however it will still just create points and that will probably depend on timebinning on import.
Hi Please also guide me - i am also stuck here - atleast one alis should be defined. What to do now - Please
