Does NTN work with mmWave bands only?
I can see n256 and n255 bands.
n256 and 255 this is about 2 GHz band.
These are not mmWaves.
This is old ITU bands for Sat. Communications.
UE for mmWave band n258 (26GHz) testing | 1 | 635 | June 30, 2021 | |
UE mmWave antenna modules | 2 | 678 | August 24, 2021 | |
Why Does CBAND (n77) Outperform mmWave (n257) Despite Same 100MHz Bandwidth? | 1 | 206 | August 2, 2024 | |
5G n77 and n78 band clarification | 1 | 2909 | November 30, 2021 | |
Does beamforming depends on the frequency band? | 2 | 295 | August 16, 2023 | |
Does Nokia mmWave have 4T4R? | 3 | 500 | October 21, 2022 | |
5G mmWave loss compared to LTE low/mid band? | 7 | 472 | July 12, 2021 | |
If UE doesn't support a band than will Event A2 will trigger for inter frequency measurement? | 1 | 220 | August 27, 2023 | |
N3IWF (Non 3GPP Internetworking Function) | 0 | 382 | August 24, 2021 | |
Vendors support for 5G NR UL 256 QAM | 3 | 405 | July 15, 2021 |
