For NR, if UE miss DCI in Downlink sent by gNB, then will UE send any response like NACK?
Will network again send same DCI to UE?
No…in both LTE and NR.
This is called DTx i.e. the UE is not able to decode PDCCH.
The gNB may increase the aggregation level in retransmission.
What happens if network doesn’t get that ACK/NACK from UE? | 3 | 408 | August 4, 2023 | |
Will gNB allocate UL resource if UE link quality poor (out of range)? | 0 | 208 | December 19, 2023 | |
What specific inputs does the MAC scheduler consider when allocating downlink resources? | 15 | 106 | October 17, 2024 | |
If CSI report slot falls on ack/nack slot then shall UE drop csi report? | 2 | 311 | March 25, 2022 | |
Is it possible for UE to send msg 3 if it's getting msg 2 rar fail? | 2 | 371 | April 28, 2021 | |
When DU receives UE Context Setup Request message from gNB-CU, what next step it does? | 1 | 416 | May 1, 2023 | |
Beam failure and recovery on Scell in ENDC scenario | 0 | 419 | October 16, 2020 | |
What will happen if UE don't read the paging message? | 3 | 582 | April 8, 2022 | |
NR disabled by UE, expected behavior? | 0 | 444 | March 31, 2023 | |
Phich decoding fail | 0 | 515 | February 21, 2022 |
