Ericsson 4G Site PM File Generation Issue
Dear Experts.
In 4G Ericsson site, no PM files are being generated in node.
Showing error ‘No xml files to parse’
Can anyone suggestion, what things to be check and other solution?
You have to check if there is a subscription statistical profile in the eNodeB.
How can we check that?
Run this command:
pst all active
And check if the counters you need are within those.
If they are not there, you must activate them from the ENM.
