Ericsson moshell
Hello everyone, I am not able to work on the DUW with this 64-bit version, does anyone else have this problem?
below is the error:
get rad noof
230131-17:42:29 169.254.1.1 22.0v RBS_NODE_MODEL_U_4_1450 stopfile=/tmp/1831
Checking MOM version…RBS_NODE_MODEL_U_4_1450
error [/home/Cliente/jarxml/RBS_NODE_MODEL_U_4_1450.xml.jar]: missing 7 bytes in zipfile
(attempting to process anyway)
error: invalid zip file with overlapped components (possible zip bomb)
To unzip the file anyway, rerun the command with UNZIP_DISABLE_ZIPBOMB_DETECTION=TRUE environmnent variable
Downloading File from \http://169.254.1.1/cello/oe/xml/RbsNode.xml.jar to /home/Cliente/moshell_logfiles/logs_moshell/tempfiles/20230131-174102_1803/RBS_NODE_MODEL_U_4_1450.xml.jar …Done.
Moving file to /home/Cliente/jarxml/RBS_NODE_MODEL_U_4_1450.xml.jar …Done.
ERROR: MOM file is corrupted: /home/Cliente/jarxml/RBS_NODE_MODEL_U_4_1450.xml.jar
Please delete this file and try again !!
do you have instruction on how to install cygwin64 for moshell 22?
Thanks in advance
You can edit bashrc file as below
Add below sentence to the end of the file
Export UNZIP_DISABLE_ZIPBOMB_DETECTION=TRUE
And the problem will be solved, there’s no need to delete anything
@ameersindy
Contact me on telegram, I’ll teach you how to install it
Thanks for the feedback, I made the change according to your instruction, but I keep getting the error, correct me if I’m wrong please
unset PROMPT_COMMAND
export PS1="[\033[1m][\w]\$[\033[0m] "
alias ls=“ls -FX”
set -o notify
set -o ignoreeof
shopt -s cdspell
shopt -s cdable_vars
shopt -s checkhash
shopt -s checkwinsize
shopt -s sourcepath
shopt -s histappend
export PATH=$PATH:/home/edils/moshell
export with small E, save the file after editing, if not solved share alarm capture.
Perfect observation, error resolved and connection to normalized DUW, thank you very much!
get rad noof
230206-15:58:37 169.254.1.1 22.0v RBS_NODE_MODEL_U_4_1450 stopfile=/tmp/1766
MO Attribute Value
Sector=1,Carrier=1,RadioLinks=1 noOfRadioLinks 33
Sector=1,Carrier=2,RadioLinks=1 noOfRadioLinks 41
Sector=2,Carrier=1,RadioLinks=1 noOfRadioLinks 27
Sector=2,Carrier=2,RadioLinks=1 noOfRadioLinks 40
Sector=3,Carrier=1,RadioLinks=1 noOfRadioLinks 35
Sector=3,Carrier=2,RadioLinks=1 noOfRadioLinks 32
Total: 6 MOs
Alguem ja tem a versão do moshell23.0B?
consegue a versao Moshell23.ob
se poder compartilhar agradeço.
English please so we can help you
Does anyone already have the new Version of Moshell?
MOSHELL23.OB
Who can share I thank
@ameersindy
Text me on Telegram
Moshell 23.0b : moshell23.0b
Thank you
thank you very much
How do you post large files here?
It is not possible / not allowed…
You need to use some site like dropbox, googledrive, etc…
hi bro,Link not Working
could you pls send again?
Have a nice day ^^
Moshell 23.0c :grinning:
Hii i have Ericsson moshell 22.0c.I am facing error to login bb 6631 with RN07 Software.Need support to upgrade.
