Hi @AbdurRehman87 …from the science direct link ,I could find the below marked line:
ok …so that means… the MSG3 retransmissions will be nonadaptive in nature and for them ,a set of identical resource blocks will be used as in the initial case (no need for and more grants)
Related Topics
Contention based RACH procedure message 4 | 8 | 5035 | April 30, 2022 | |
RRC Connection Setup SR is 5% only | 32 | 2186 | March 7, 2021 | |
In LTE what could be the reason for No RACH Attempts? | 19 | 3117 | August 2, 2021 | |
LTE Random Access Procedure (RACH) | 1 | 11915 | April 13, 2021 | |
LTE RACH contention based timers | 15 | 1760 | August 4, 2021 | |
UE using Contention Based RACH Preamble | 10 | 2823 | December 18, 2023 | |
What happen if after HARQ max retrans, UE still report NACK? | 12 | 614 | May 10, 2021 | |
“5G NR Bearer Drop” with SCG failure “randomAccessProblem” | 11 | 8547 | May 31, 2023 | |
Site taking traffic only after modifying PRACH config index | 6 | 1238 | July 22, 2022 | |
RLF cause as PDCP UL release in UE LTE logs | 22 | 3491 | July 19, 2024 |
