Hello Experts,
Why RRC_INACTIVE State is required in 5G NR?
Hello Experts,
Because of less frequent transactions with the EPC I believe.
S1 bearers are not released.
Reduce the latency to transition from IDLE to CONNECTED. It is useful for low latency services.
Dear Experts.
Is RRC Inactive State optional or mandatory in 5G?
Does any vendor have feature to enable/disable RRC inactive state?
It’s optional.
Nokia has option to enable / disable it.
Basically it’s for mMTC / uRLLC use case.
Thanks.
So it is not used for eMBB?
It can be, but is more targeted for mMTC / uRLLC use case.
Here is a nice video with straight explanation on RRC Inactive States in 5G NR:
Source: Telco Bytes
Also check nice summary compiled by @vikas.nain here: Summarizing 5G RRC Inactive state and comparing with other 5G RRC states
Do Ericsson, Huawei, Nokia support RRC_Inactive state in current releases?
