For LTE once UE powered on below steps mentioned on Sharetech Note:
i) Power-Up Test
ii) Frequency & Time and Frame Synchronization
iii) Decode System Information Message
iv) Select Prefered Network
v) Perform RACH Process
vi) RRC Connection Setup
In my view after step2 PLMN scan step to be included ie before decoding SI as well what views of group experts or it after step 3.
I have same view but I read UE will go for PLMN scan before reading SIB i.e. intial PLMN scan and then cell selection happen on that PLMN.
Need more clarity.
Are you sure that in step iv, UE will send PLMN to NAS layer and if rejected by NAS Layer then it will try searching new cells?
Or
it will search all cells and create a list of PLMN from all broadcasted cells and then send that list to NAS layer and NAS layer pick one of desired PLMN and starts registration process.
UE only checks the energy it received from its surroundings, that time ue was not sure of RSSI since RS decoding will be done only after pss&sss serving
Where ever UE find the energy level greater than the threshold defined inside UE (non 3gpp) it creates a list of all energies detected above that threshold and starts scanning one by one.
So, If we move from one place1 to another place2 inside country by flight then there is a possibility area1 had some bands which are not present on area2, then from beginning deviated band scan will be started, ue system scan won’t be fruitful here.
