Mobility Robustness Optimization (MRO) Feature
Throughput can degrade because you delay the HO, mainly if traffic and PRB increases.
For low traffic I believe it will improve.
MRO is based on handovers too early or too late.
And RLFs counting based on the 2 counters above.
What is ping pong? :thinking:
Excessive handover between two cells.
MRO is mainly control CIO offset for late and early HO.
There are counters in Huawei for late and early in neighbor relation, but mostly that counter is still not that clear to assume. You need to check ncell atttempts and timing advance of serving anf neighbor cells.
If your serving is more than 30 percent samples where in cell edge if its is more than 20 percent samples, then its case of overlapping or ping pong, its really a headache to see this much in reality.
30 percent samples with first tier nbrs.
Already checked.
And choose highest ping pong cell, but afraid if any KPI will be impacted.
Drop can in crease try in some cells mainly in low PRB case.
And traffic.
This is the point.
To minimize RLFs during HO, does MRO feature dynamically change the CIO after observing threshold (particular no. of RLFs) of too late or too early handovers? If yes, plz share call flow.
MRO (Mobility Robustness Optimization) appeared in SON (Self Organizing Networks) in LTE Release 9.
  • Used to configure some parameters at base station to delay or to fast the Handover between 2 cells to improve HO performance.
  • Handover paramters like CIO (Cell individual Offset) or TTT (Time to trigger)โ€ฆ etc.
This will enhance the mobility performance specially at the cell borders.
Hi,
What is the limit acceptable for adjacents cells ? Is there condition about carriers for overlap parts ??
