Hi @Medhat.Khalifa
No UL Data volume Reduce more and DL Data Volume reduce Marginally.
We are able to manage the KPIs and adjust few internal system constant change, but I am more curious to know the reason. What in RAN L20.Q1 can impact the Initial RRC Setup Rate % and Improve RACH SR %.
Please do check the Network Impact Report available in Alex for this SW release, every release has some changes/additions for the parameters and counters behaviors, etc.
You have coverage levels for control messages repetition, (0,1,2) check the RRC/NPRACH for each level, i believe level 1/2 are degraded, so disable 1/2 and keep 0 On.
