Severe degradation of E-RAB Success Rate in specific cells only
It will increase signalling.
What about RB utilization?
There doesn’t seem to be a huge impact.
Yes, not much (nothing).
Dfrom 14 to 16 there was Transmission issues (fixed).
Anyways it’s a solution.
What about PDCCH utilization?
It must have increased a lot…
CCE has increased.
What about DL Throughput?
Slight degradation though.
But it is normal (expected), you have more users/RAB.
So it is normal DL Throughput to degrade.
Yes, exactly.
If PDCCH agg is good then change max code rate from 75 to 85.
Through put will be improved in that condition.
But if not required ignore.
That’d be a good improvement, but what I caring about at the moment is the Accessibility until we have expansion.
Obviously, expansion is required.
Obviously, no option. :wink:
This is PDCCH Agg.
Put the bar line on changes Day and compare Pre/Post days…
Pre:
And Post:
Pls check enb cpu load peak hour?
