Hi Experts!
Let me to describe my issue that I am thinking about.
There are 2 operators (Operator 1, Operator 2). They are share the same 5G band, for instance n78 (it is TDD frequency). All 5G optimization articles say that both operators should use the same TDD frame structure otherwise they will make interference to each other if Operator 1 use DL slot, but Operator 2 use UL slot simultaneously. Ok, it seems very logical, but obviosly that in real life both operators use different NR-ARFCNs, so my question is:
Why does different TDD frame structure cause interference between operators if they use different NR-ARFCN?
Ok, Operator 1 use DL timeslot, Operator 2 simultaneously use UL timeslot, but they are using different frequencies.
Vector
1
Related Topics
What happens if two 5G neighbor sites are configured with different tdduldlpattern 0 and 1? | 2 | 331 | December 14, 2022 | |
Can overlapping ARFCN in most of the NR bands cause interference? | 0 | 427 | December 23, 2022 | |
4G TDD interference due to GPS sync issues | 3 | 1959 | October 5, 2021 | |
Change in Subframe Type issues? | 0 | 430 | February 20, 2020 | |
LTE interference on NR | 1 | 323 | February 9, 2024 | |
Can UE measure crs of 2 sites at the same time? | 3 | 430 | March 22, 2022 | |
Overall Cell Throughput of single UE is lower than of 2 UEs | 2 | 414 | December 30, 2021 | |
Same site with Different Bands for Different Operators | 4 | 368 | October 21, 2022 | |
Reasons for carrier overlaps | 3 | 686 | April 8, 2022 | |
Is this possible both TDD-LTE and 5G NR work in the same band? | 6 | 1062 | June 3, 2022 |
