Hi dears.
I have UETR file, from ericsson messurement.
And am searching TA in this file, but not finding.
Any suggestion?
Hi dears.
Any suggestion?
If its Layer3 trace then unlikely you will find anything in this trace regarding TA.
TA is largely mac layer function at start-up.
Check Ericsson Internal event in layer 3 recordings, Internal_per_radio_ue_measurement_ta
This can be fetched from which recordings on pmic (ue or cell)?
CTR , UETR both.
Thanks, I already find it in UETR.
For 3G imsi traces.
Which is propagationdelay.
Now am searching how to do 4G| imsi traces for specific imsi?
