csi-MeasConfig setup :
nzp-CSI-RS-ResourceToAddModList
nzp-CSI-RS-ResourceId 0,
resourceMapping
frequencyDomainAllocation other : '000001'B,
nrofPorts p2,
firstOFDMSymbolInTimeDomain 13,
cdm-Type fd-CDM2,
density one : NULL,
freqBand
startingRB 0,
nrofRBs 68
powerControlOffset -5,
scramblingID 261,
periodicityAndOffset slots320 : 261
It is available in rrc connection reconfig message as doubted.
These will be usually periodic messages.
You need to go into the message and check SFN and Slot number to compare the periodicity.
But in CSF report , CRI records are mentioned aperiodic
Record[2]
report_ul_time
slot : 65
numerology : 120kHz
frame : 935
carrier_id : 0
report_id : 1
report_type : APERIODIC
num_bits_part1 : 24
num_bits_part2 : 0
is_rsrp : RSRP
num_bits_part2 : 6
debug_only : Result_from_WP
report_quanlity : CRI , RSRP
resource1 : 0
resource2 : 1
resource3 : 2
resource4 : 0
resource_type : CSI_RS
num_resource_bits : 3
pad : 0
rsrp1 : 76
rsrp2 : 62
rsrp3 : 59
rsrp4 : 0
valid_rsrp : 3
For periodic reporting it will be mentioned in RRC reconfig message as below right?
320 slots with 120Khz scs = 320 *.125ms = 40ms
