Ok thanks dear. I also feel globally no network used extended CP in LTE.
cheikh789
23
ECP adds overhead thus decreasing the effective bit rate & lowering capacity, i.e. 6 versus 7 symbols exist per timeslot.
Related Topics
How Normal CP is supported in 240 kHz SCS and not extended CP? | 8 | 706 | January 5, 2022 | |
Cyclic prefix length for symbols in 5G frame structure | 1 | 1027 | December 6, 2022 | |
In NR SCS, why do we have extended CP only in 60 kHz? | 2 | 1767 | November 1, 2023 | |
2 eNodeBs using same Root Sequence Index | 15 | 5461 | August 1, 2021 | |
Why first and seventh cyclic prefix is larger in 5G in each slot? | 3 | 173 | July 28, 2024 | |
NR PRACH queries related to configurations and parameters from spec 38.211 | 0 | 511 | August 9, 2021 | |
How Cell Size is determined from length of preamble format? | 37 | 11663 | December 2, 2022 | |
Short preamble and msg1 frequency start | 10 | 3158 | December 11, 2023 | |
Why PRACH is used in LTE and how to plan PRACH/ preamble format in a network? | 4 | 2209 | July 28, 2021 | |
Does split bearer always use NR PDCP? | 15 | 3137 | August 27, 2020 |
