2G integration from BSC
Dear Experts,
I am doing first time integration of 2G BB from the BSC , I get the CDD as there are too many lines and I am confused how to run the entire parameter . is the any way to run them in one shot from winfiol.
I need your guidance .
BR//
Hi @Sebastiansilver, try this: open command file in winfiol, associate it with bsc’s channel, select all (CTRL+A) or required rows, then press F4.
Great help, thanks a lot
BR//
