3G to 2G per Neighbours stats shows HO attempts were made to undefined 2G Neighbours from 3G cell. How it is happening?
Bansuri
2
This is probably a db mismatch. Ideally, for a handover to 2G, you are defining not just the ARFCN but the cell ID and other details as well and hence a handover to “unknown” cell cannot happen.
Related Topics
2G-3G neighbour definition impact | 5 | 1758 | July 24, 2020 | |
Issues with CSFB for 2 Operators | 9 | 1247 | April 29, 2021 | |
What could cause IRAT preparation failures to unknown target RNC on a site? | 13 | 3113 | May 5, 2021 | |
If LTE to 3G neighbors not defined, will there be NO CSFB attempts? | 18 | 1742 | September 25, 2021 | |
Intra-frequency Handover LTE | 10 | 3546 | September 13, 2022 | |
Issue in fast return from 3G (Nokia) to 4G (Huawei) | 9 | 4495 | September 15, 2018 | |
5G HO inter gNB Failure | 0 | 327 | March 22, 2024 | |
Cell-not-available 4G Handover Failure | 2 | 2793 | March 20, 2021 | |
2 cells with same eARFCN and PCI | 16 | 6356 | March 22, 2022 | |
UE locked in 2G cannot make calls in 4G/3G/2G layers cell | 22 | 1135 | March 6, 2021 |
