Hi has anybody heard something like this?
Ericsson 3.5 GHz Power Boosting feature when use also NR 700 on the same site in NSA 5G NR.
If you have 20 MHz bandwith and in TDD mode on 700, you can try first with 3db boost on SSB. It will decrease the throughput a little bit, but the overall footprint will increase and by that the volume. To compensate you can activate the NR Data plus DMRS multiplexing. If its on 3.5Ghz, 6 db is fine for suburban, urban 3 db also.
