3G Parameters to change the frequency to look for LTE
Hi TelecomHall family.
What 3G MO we have to change the frequency to look for LTE❓
Vendor E///
Do you mean reselection from 3G to 4G?
You require a script for defining 3G to 4G.
If is possible yes it is better.
And if you help me with ANR script for LTE I appreciate it.
This has to be defined in 3G site, but please check all the thresholds as per your n/w requirement.
And above snippet is for only one cell, you need to define it for all cells in that particular site.
Post creation of the RELATIONS check these thresholds:
