3G reselection issue among different vendors
We are facing a 3G reselection issue in an area with 3G in ZTE and 2G in Huawei.
What are the parameters to check in 3G and 2G network? (Thresholds and Timers that needs to be checked).
Thanks.
Reselection from which technology to which technology?
2G to 3G is not happening once call disconnects.
However cell selection is OK.
After call disconnected, there is a feature called: “Fast reselect after call release”.
For ZTE?
No, in Huawei.
You have to enable it on Cell level, it’s like a fast return.
Parameter is CELLSELECTAFTERCALLREL in GCELLCCAD.
Actually 3G is ZTE.
Yes, we got you.
But you issue is on 2G - not going to upper layer.
Thanks.
I will check.
Hi @cjounda, i’ve checked.
It’s already enabled.
