Hello Experts,
Do you know if 3G cells can be impacted (as a noise) by newly operated sites from different operator?
Hello Experts,
Yes it’s posible.
This is my view:
RBS-RBS Interference (no co-location) (differente Operators)
Hope it helps
Check the spectrum analyzer on the problem sites for the bandwidth in the Uplink base stations of your network. You should see the source of the interference.
Possible causes of interference:
All above points are checked and considered but still we have high RTWP, so after deep checking we found the illegal repeaters that used by sub have higher impact on 900 band.
So do you have idea how we can solve it please.
Illegal repeaters? The only way I could think about is stop transmitting after a reporting to the country administration.
