A NTN (Non-Terrestrial Network) refers to a network, or segment of networks using RF resources on board a satellite or UAS (Unmanned Aircraft System ) platform.
In case of satellite communication, Non-Terrestrial Network typically features the following elements:
A satellite as NTN payload, which may implement either a transparent or a regenerative (with on board processing) payload
One or several sat-gateways (NTN gateway) as an earth station located at the surface of the earth that connect the Non-Terrestrial Network to a public data network. An NTN Gateway is a TNL (Transport Network Layer) node.
A Feeder link or radio link between a sat-gateway (NTN gateway) and the satellite (NTN payload)
A service link or radio link between the user equipment and the satellite (NTN payload)
User Equipment are served by the satellite within the targeted service area.
In case of 5G, 3GPP Non-terrestrial network is an NG-RAN consisting of gNBs, which provide non-terrestrial NR access to UEs by means of an NTN payload embarked on board e.g. a satellite and an NTN Gateway. In the 3GPP specification(Release 17.3.0), the NTN payload is a TNL node.
Here I try to depict Transparent satellite based NG-RAN architecture.
LinkedIn: Rahim Navaei on LinkedIn: #5g #5gnr #4g
