I need 5g call flow diagram for STANDALONE
- Cell search
- Call initial access
- Random access
- Rrc procedures
- Handover ( intra, inter frequency)
- Pdu sessions
Thanks ameen… In 5G DRB type is same as 4G . Since 5G Qos flow is used what are the types of DRB in 5G
Anyone having detailed 5G call flow?
Yes there is on Eventhelix → just check Favs.
For eventhelix we have to click on every message one by one to check for important IE’s.
I was specifically looking for a doc with important IE’s on every message.
5G Architecture is a change to cloud from dedicated hardware (specialized hardware). 5G core network moves from 3/4G dedicated hardware to cloud or virtual machines. Radio also moves from dedicated hardware BaseBand Units to CloudRAN or OpenRAN.
Now Mobile Network Operators are not constrained to a single vendor.
Mobile operators can also roll out features faster with a simple software upgrade.
Read article now:
here is a call flow diagram from a real VoNR call.
nearly 500 messages in total, you can see all the messages at this site:
http://shark.haohandata.com:20280/work-bench/flow/1709775421010101290
