what are the parameter to check for 5g network
Signal level,quality, throughput, etc
PDSCH BLER
PUSCH BLER
Residual BLER
MCS
SNR
BRSRP
PUSCH Power
Rand Indicator (RI)
CQI
Thanks for sharing… the value you have shared it’s for throughput … I need for signal level, quality
Dear,
When drive test data is available include graphs showing some or all of the following metrics(Based on Customer requirement) vs DL & UL throughput as mentioned above by [samohiuddin];
• SS reference signal received power (SS-RSRP)
• CSI reference signal received power (CSI-RSRP)
• SS reference signal received quality (SS-RSRQ)
• CSI reference signal received quality (CSI-RSRQ)
• SS signal-to-noise and interference ratio (SS-SINR)
• CSI signal-to-noise and interference ratio (CSI-SINR)
• SS reference signal received power per branch (SS-RSRPB)
