5G frequency reuse
Hello, I wanted to know if in 5G NR whether all base stations of a particular operator have the same frequency allocation (centre frequency and carrier width) within a given NR-band?
For example, if an operator has 100 MHz in the C-band, will all base stations use the full 100 MHz or is the 100 MHz divided into channels, with channels allocated to BSs to avoid interference?
Thank you.
Typically the operator will use full bandwidth on all sites.
Thank you.
So this means there would be full co-channel interference, so there is no frequency re-use?
yes, like you have in LTE
