5G NR Frame Structure
Efficient frame structure is crucial for managing data transmission across a much faster and more flexible wireless networks. Key components:
  • Frame:
    • In 5G, the frame duration is also 10 ms
    • It consists of 10 subframes, each of 1 ms.
  • Subframe:
    • 1 ms long and contains a varying number of slots basis subcarrier spacing
    • With flexible subcarrier spacing (15 kHz to 240 kHz), the number of slots per subframe can change (e.g., 1 slot for 15 kHz, 2 slots for 30 kHz, etc.).
    • Subframes are critical for scheduling, can prioritize control information.
  • Slot:
    • The slot duration varies based on the subcarrier spacing:
      • For 15 kHz spacing, a slot is 1 ms long
      • For 30 kHz spacing, a slot is 0.5 ms, and so on.
    • Each slot contains 14 OFDM symbols (with normal cyclic prefix)
  • Resource Block (RB):
    • Number of subcarriers over one slot
    • RB size vary basis subcarrier spacing of 15, 30, 60, 120, or 240 kHz.
      e.g., 30 kHz spacing - RB spans 360 kHz (12 subcarriers × 30 kHz)
  • Resource Element (RE):
    • Smallest unit of data transmission - one subcarrier in frequency domain and one OFDM symbol in the time domain.
  • Numerology and Scaling:
    • Different numerologies are used basis service or deployment scenario:
      • 15 kHz spacing widely used in lower frequency bands.
      • 30 kHz, 60 kHz, and beyond allow for faster data rates and shorter slot durations, ideal for higher frequency bands and low-latency applications.
Note - There are 489/960kHz subcarriers also, but rarely used.
