5G NR Wake Up Signal
Hi,
Has anybody worked on the NR Rel16 feature Wake Up Signal?
Think WUS was first introduced in LTE Rel15.
Could be, haven’t worked on it though.
I have questions on NR config.
Go ahead and ask.
I will try to help, if I can. Otherwise someone else from the community will do hopefully. :wink:
Basically trying to understand how the IE ps-WakeUp works.
Does anybody has tested using this.
