Hello
Is there a software to get uplink SINR of 5G NSA on Huawei device ?
Uplink SINR is only calculated on the gNB so it can only be seen at the gNB logs. You cannot see that from the UE logs or at the device end.
UE-Side SINR calculation and accessing SINR values on Android | 0 | 8 | November 14, 2024 | |
Is there any tool which captures End to End VoNR Call Flow? | 4 | 635 | October 15, 2022 | |
Website showing 5G SA or NSA network | 0 | 32 | August 26, 2024 | |
Is there any way to capture the angle of arrival (AOA) in 5G /4G? | 3 | 294 | February 1, 2023 | |
SINR and SNR in Atoll software, or any other type of manual calculations | 0 | 36 | October 17, 2024 | |
Tool to decode gNB BCH | 1 | 374 | October 20, 2022 | |
5G UE and RAN (gNodeB) simulator | 2 | 540 | March 19, 2024 | |
How to get the IMSI of a UE on Huawei network? | 3 | 40 | September 10, 2024 | |
5G NSA RE Power check using drive test | 2 | 557 | April 6, 2023 | |
Calculate the 5G online time in ENDC | 0 | 365 | May 11, 2021 |
