I need what the reason for RACH attempt failure?
• PRACH root sequence clashes
• Antenna radiating beyond cell range
• PDCCH congestion & Coverage issue
RSI collision
You can check cell range(zero correlation value)
Coverage holes
These are the first three things along with you can check overshooting cases as well….
Any parameter to check in RACH configuration?
There are 4 message in RACH procedure for each message what are the related parameters?
Hi @Vijay_Anand you can check the RACH parameters in details in this article RACH Procedure 5G/NR 4 Steps with IE
