Hi,
Required information how to check Ue Power in XCAL drive test tool
Regards,
Vijay anand
Hi,
Regards,
Vijay anand
Hi,
you mean the maximum power UE can do? That would be in UE capability message.
The maximum allowed UL power in cell (Pmax) is in SIB1.
Actual UE transmitted power is in PUSCH power control messaging.
Hi thanks for reply i actually need Ue TX power , From XCAL drive test tool where can i find out Ue TX power , How to measure the Ue Tx power
in XCAP there is a PUSCH Power, not sure if in XCAL
Will check and let you know
I would look for B884 from Qualcomm log.
