I just read a IEEE article, and in this article mentioned that in 5G, UE will send its service requirement to gNodeB such as bit rate or latency or loss range.
Is it true that UE will send these data and gNodeB will check its requirement?
Related Topics
Does UE with CORE restriction measure 5G NR cell? | 2 | 371 | February 21, 2021 | |
Why does gNB need IE NeedforGapsInfoNR from the UE? | 0 | 243 | March 22, 2024 | |
Will gNB allocate UL resource if UE link quality poor (out of range)? | 0 | 208 | December 19, 2023 | |
Measurements for NSA DC UE Mobility Cases | 0 | 556 | October 7, 2020 | |
B1 Measurement config after Blind Leg Addition | 0 | 426 | January 27, 2023 | |
Government worldwide 5G QoS requirement | 2 | 132 | June 14, 2024 | |
Value of SINR below which UE will not be able to latch onto 5G network | 1 | 459 | September 11, 2023 | |
When DU receives UE Context Setup Request message from gNB-CU, what next step it does? | 1 | 419 | May 1, 2023 | |
Are NR UEs allowed to transmit over 100 MHz bandwidth in UL? | 2 | 407 | May 21, 2022 | |
What will happen if UE don't read the paging message? | 3 | 582 | April 8, 2022 |
