HI,
Have you heard a type hoot or openvoice or always on
channel. Those channel is always on after start up and never stop if no
issue .end user can always talk and listen through it . It use Channel
Associated Signaling .
Do you have those ABCD bit pattern ?? I heard
some one tell me there is only one pattern 1101 and that is all . Do you
have any idea and spec for this ??
Please advise
Related Topics
What does eNodeB do as soon as it power on? | 4 | 344 | July 31, 2021 | |
Scheme connecting RCD with UPEU, in BTS3900 | 0 | 314 | February 25, 2023 | |
Configuration Data Inconsistency alarm | 0 | 128 | April 16, 2024 | |
CCO SON behavior when we share antennas with 3G, 4G | 0 | 418 | October 5, 2020 | |
Abnormal alarm of PCI conflict or abnormal ANR behaviour | 4 | 2217 | August 31, 2017 | |
QCL Quasi-Colocation Concept in 5G NR | 1 | 2337 | February 21, 2021 | |
Max neighbor relations exceeding in LTE, NSA, and SA networks alarm | 1 | 11 | September 9, 2024 | |
Understanding the call flow of MO/MT calls in the CS network | 1 | 308 | April 25, 2024 | |
Switch to ignore call drop drop after hang-up | 0 | 608 | July 8, 2020 | |
GPRS Location Update Channel | 0 | 253 | May 13, 2024 |
