Hi, anybody knows how to access EVO BSC thru moshel or amos.
I used moshell -v comcli=34 BSC but it didn’t work, anybody has experience of it?
Thanks.
Hi, @amer1562, this should work:
amos -v comcli=34,username=OSSUSER <ip>
Thanks for your reply.
But i am already in OSS, i am using the amos of OSS, why username is needed?
And if username is already, oss password is not needed? Is there EVO BSC which you access it only with winfiol or all EVO BSC are accessible thru moshel?
@amer1562, that was long time ago. As I remember username is required and password is optional. I can connect with moshell to any BSC.
I wonder if there’s any settings needs to be done on the BSC in order to access thru amos using ssh protocol because it tells me “unable to connect to IP:22”
Maybe you need a proper access rights. For ENM I have roles Amos_Operator
, Amos_Administrator
I guess i have these roles. I am suspecting some settings on the APG43L of BSC needs to be done.
There are no settings that limit 22nd port or amos. If ssh works, amos works.
amos won’t work if the node’s MOM version is not ready.It will be displayed at the moshell uservariable default_mom.
Please check this first, otherwise “lt all” will do nothing
Hi, i cannot even access the BSC to check the default_mom.
just use telnet or ssh. If when connected the BSC does not recognise AXE commands, write “mml” (man to machine language) and the prompt will change
but I prefer WinFiol
