Traditionally HARQ BLER Target of 10% is used in Ericsson RBS.
Also the same value is used in Huawei as the Initial BLER Target Value (10%)
But Huawei provides the Adaptive Target BLER Functionality that helps then gain better spectral efficiency and throughput.
As per my knowledge and the Sw Release we have 18.Q4 Ericsson do not have such flexibility. Plus no possibility to change that 10% target BLER as it is Hard Coded I believe.
Do you know if Ericsson has any equivalent available (Hidden Parameters or System constants) to the Huawei flexibility?
Huawei has a feature “Adaptive Target BLER”, a functionality that helps then gain better spectral efficiency and throughput.
Anyone know about that feature and its functionality?
Is it same the link adaptation?
Yes, sorry, my bad.
I meant to ask if anyone saw the benefit of increasing target bler >10%?
MCS would be higher but overall gain want because of higher retransmission rate.
Do you know the exact name of this feature in Ericsson?
I’ve not seen it before.
It is hardcoded to increase BLER in Ericsson greater than 10%
Don’t belong to a feature…
Parameter Current Value Proposed Value
dlBlerTargetEnabled FALSE TRUE
pdcchTargetBler 24 200
pdcchTargetBlerPCell 22 180
See we have three option for bler.
dlBlerTargetEnabled this one related to ericsson lean carrier feature so please skip it.
But for two other remaiend MO you can set it to 200/180 and see the result.
In scheduling algorythm the enodeB will elimiate those users which consuming more resources because of the retransmisson.
So you will see after modification DL THR improvement but a bit active users reduction.
Active users will be reduced because less users will be remained in buffer.
But no change in payload generation because most users working like before.
