aDAS vs. pDAS
Hi ,
Can anyone tell what are the drivers for selling aDAS , since aDAS CAPEX is higher than pDAS . So , how come the benefits of aDAS will offset the higher cost of aDAS over pDAS
Benefits of active DAS is that you don’t need to build complex feeders path with multiple passive elements which could not be monitored. Active DAS require only optic-cable installation - no feeders!
Traditional DAS have limitations in terms of scalability, maintaining, time to build feeder path and performance.
