Any idea about an AI tool that saves time to visualize KPIs reports from generated network CSV reports?
It consumes time to do it manually on Excel.
Check Power BI or Tabelau.
I suggest you to see:
Actually you can do a couple of things.
If you will use this (thing) only for monitoring, then you can use EXCEL VBA. It’s a quick one and into the point.
If you will use it for Analysis as well, you can either use Tableau or Excel. Use their powerful Quèry and data models to make reports.
