In a call scenario from VoLTE to 2G how the AMR codecs are synchronized at runtime?
And if during the call VoLTE is using NB12.2 UL/DL codec and 2G is using 7.4UL/DL, then will there be noise distortion?
Thanks
Thanks
During negotiation it gets appropriate codec up to 12.2 in GSM or EFR/HR.
Thanks!
Once the codec is negotiated in SIP message and call is established, then if 2G moves to a poor coverage, and its codec changes based on C/I, how will VoLTE user know which codec to tune to?
And if there is any mismatch in codecs will the user face distortion?
When Callee is on CSS network, MSC / Transcoder is involved, which adjusts codecs at Callee.
Caller (SIP based) codec remains as per its preference and compatibility with MSC / Transcoder codec sets.
So, callee codecs remain independent of caller codecs.
It’s just an observation that MOC UL Codec should be same as MTC DL Codec and if there is any mismatch voice muting is observed.
This is not normal, should be verified with e2e traces. At each moc and mtc end, transcoding at SBC/p-cscf(ims) or MSC/TRAU(cs) is done. Supported codec list at these nodes should be extensive and trancoding features should be defined as per vendor recommendations.
You can have both ues; one with evs and other with amr…one with amr wb and other with amr nb.
