Does anyone know which spec explicitly mentions antennas required for 5G devices?
Should be 4?
Should be 4?
I found this on internet: The standard requires 4 RX (reception) antennas for 5G bands with 3.5 GHz (TDD) as well as n7 2.6 GHz (FDD), n38 2.6 GHz (TDD) and n41 2.5 GHz (TDD).
Maybe not for all bands 4 RX antenna are needed for 5G.
For example Samsung Galaxy Note 20 Ultra 5G in n28 works only with 2 layers:
Mostly bands under 1 Ghz are 2 layer at UE side for both LTE and 5G.
Thank you. Do you know the spec #?
