Any ideas for sharing load from priority carrier to secondary carrier?
hi all ,
do you have any idea for sharing load from priority carrier to secondary carier ?? The vendor is Huawei
you can use interfreq MLB, I guess
by changing cellqoffset and cio … by changing values of a1/a2/a4 values
Can also change qhyst
MLB function will help u
MLB function is time dependent.
Hi,
you can set the reselction parameters snonintersearch;threshsevinglow and on lower layer to set threshxhigh
just keep the rule of threshxhigh>snonintersearch>threshservinglow to avoid cyclic reselection between carriers
