Hi All.
20 meters away to the apartment that I would like to tent, there is a sector directly seeing this apartment.
If we consider the 4.5G base station is emitting max power, what is the signal strength I would measure in the apartment, roughly?
Do you think that it is harmful?
Thanks in advance.
Yes, but the power is exponentially dropping, so do you know the max power emitted and the approximate power 20 meters away?
I think it’s already established that these radiations are non-ionizing.
So don’t think you have any harm.
Signal strength is likely to be best RSRP/RSRQ.
Buy the best package and stream all you can.
Unfortunately Non-ionizing also has it’s own harm.
If someone is interested, study this book
It only has heating affect afaik.
Based on what I studied it’s not all about heating…
I will read the book thanks for sharing @iman.mohammadi.
