Any suggestions for high cap LTE in Huawei…To improve user throughput?
Dual carrier???
Single carrier…Any parametric changes suggestion!!
First check transmission issue
Idu and odu capacity
And pdsch licence
Odu port setting and go for ip 20c configuration
How many mhz???
FDD or TDD???
Fdd…5 mhz
First you check above point still you can’t handle I have one solution…Where you can take resources from neighbouring sites
Almost a standalone site
Its didn’t get …its high cap for MW…Can u explain in detail IP 20C means?
Ask your transmission expert
We want all parameters level not BSS or TX issues.
So request all please explain only optimisation scope No Tx,Bss or Alarm issues
Brother transmission issue is biggest issue for throughput
If you don’t want to understand then leave it ask other
Here my prb utilisation is greater than 80 percent causing lesser user thpt…so any parametric changes or high cap settings u can suggest!!
Please request TX issues is not Opti scope …its backhaul issue or IP Radio issue its depend on NW
There is no fluctuations or MW is 100 Mbps & backhaul is 1gbps found in End to end throughput testing …now can suggested any parameters
You need bandwidth…More for this…TDD
Kindly suggest parameter tuning.
You need bandwidth
How much…
Everyone want to improve only no buddy wants to know what is the problem just suggest parameter
Ask other experts
What is average Cqi… sinr… users… prb… tx port setting … only paramter and paramtet will not help
It’s OK if single site on End to End throughput 1 GBps in testing .
U can try improve rb usgae … Decrease ue inactivity timer
