Anyway to ping from a Ericsson ENM CLI command?
Hello i would like to know if there is ping command in CLI ?
I need to check if my BB and DUG/W/S are joignable without checking one by one in the enm.
In my best world it would be:
ping --node SiteName
or
ping SubNetwork=ONRM_ROOT_MO,SubNetwork=LTE,MeContext
Thanks for the help :grinning:
Hi, @Hugo_LE_GALL, in the CLI you can only ping from DUW(S) using cmedit action.
Thanks mate, any alternative solution?
Some of them can be ping by CMD but some other no
@Hugo_LE_GALL, the alternative is amos/moshell and grep logs for results.
and how to use the ping, i’ve tried:
cmedit action SubNetwork=ONRM_ROOT_MO,SubNetwork=LTE,MeContext=RBSNAME,ManagedElement=1,IpOam=1,Ip=1 traceroute
Error 1016 : An incorrect action name (traceroute) has been encountered for the type Ip possible value(s) are [ ]
Suggested Solution : Provide a value from this list: []
I’ve tried the command in the help section with the ip found in : nodeIpAddress (this is the ip used by my dus)
Hi, @Hugo_LE_GALL, actions ping and traceRoute is on IpOam object. You can verify in amos with command acl . ping.
