Hello experts,
1.Can we take a copy of DUW folders (c and d) remotely using ENM.
2.or can we take a backup that includes license and fingerprint for DUW remotely.
Appreciate your help.
Hello experts,
Hi, @Amir
sftp://rbs:rbs@<rbsip>/
http://<rbsip>/keyfiles/Licensing.xml
Thanks alot
Do I have to login to site to do this?
What about the fingerprint?
My goal is take a backup for c and d then use them on another DUW
For downloading license you don’t need to login.
Fingerprint is stored at:
/c/node_id/node_identity.txt
or you can get it in amos:
get licensing=1 fingerprint
Hi @vlr9999, I have tried this method it gives me No such file or directory
Hi, @Amir the link above is for example. On ENM or linux the command is:
sftp
rbs:rbs@10.28.28.28
where rbs is a default DUW login and password. You need to use yours.
