For NR, why bandwidth supported indicated 2 times?
In UE capability info ie dl bw FR1 and per cc downlink field?
Which one need to consider for config part?
How to verify intra band non-contigurous CA UE capability with the supportedbandcombinationlist | 0 | 27 | September 4, 2024 | |
How many BWP defined from gNB to UE? | 80 | 304 | September 26, 2024 | |
UE support single or dual registration support in 5G SA | 9 | 252 | September 11, 2024 | |
Check SupportedBandCombination for CA | 0 | 104 | July 25, 2024 | |
Mapping of featuresetCombination for a supported band combination in NR | 4 | 65 | September 10, 2024 | |
Multiple closed-loop uplink power control processes | 0 | 463 | April 27, 2022 | |
How Bandwidth part is taken care in Carrier Aggregation in 5G? | 10 | 962 | October 11, 2020 | |
For 5g NR-DC, can we have FR2+FR1 or its always FR1+FR2? | 2 | 662 | March 19, 2022 | |
BWP0 Configuration: Recommended Bandwidth in MHz | 0 | 8 | October 19, 2024 | |
How UE indicate the presence of csi part 2? | 0 | 1429 | March 15, 2021 |
