Hi Gentlements! Does anyone know how to extract the temperature reading from the basebands 5212/5216/6630 from the manufacturer Ericsson? Thanks a lot.
Hi, in AMOS/CLI
show-counters ManagedElement=1,Equipment=1,FieldReplaceableUnit=BB-1
or in stat pmUnitTemperatureLevel
no any legal way
Humm⦠and if you try this?
te e all BC_TEMP
te log read | grep TRACE2 | awk β{print $1" β$2β β$21β β$22β β$26β β$27β β$30β β$31β "$32}β | sed βs/"//β | sed βs/,/ =/β
Is it correct read sensorId = 0?
temperature: 29500 (mC)
It looks like milli celsius (mC) or something
Itβs 29,5 C. So, yes - that milli celsius.
Anyone have information about the possibility of setting temperature ranges (if possible) for BB - turning off BB below -10 degrees (as example), overheating above 45 degrees (also turning off BB)?
Hello friend, Iβm trying these commands and I donβt have any results, could you tell me how to get this result?
