Dear collegues,
Does anyone can explain what is the difference in battery consumption on LTE with and without DRX? Specially for VoLTE.
Bega82
1
Related Topics
What is the disadvantage of disabling DRX on 4G? | 4 | 634 | May 21, 2022 | |
LTE UE power consumption between RRC-inactive timer short and long | 1 | 450 | June 19, 2021 | |
What is the difference between fast dormancy and DRX in 3G | 1 | 20 | November 1, 2024 | |
PRB Utilization if switch off VoLTE or reduce B2 threshold | 0 | 659 | April 1, 2020 | |
Can we use eDRX for LTE devices or is it only used for NB-IoT devices? | 1 | 657 | January 22, 2024 | |
What is the impact of "nomPdschRsEpreOffset" in LTE DL power allocation? | 0 | 1016 | May 21, 2021 | |
RSRP degradation after enabling VoLTE | 1 | 419 | November 11, 2022 | |
Negative impacts on LTE data service when using DUAL-SIM phones | 0 | 276 | June 4, 2021 | |
3G shutdown impacts on VoLTE | 4 | 710 | October 25, 2022 | |
Can DRX period be used for inter freq Measurements if network doesn't configure measurements gap in LTE? | 1 | 516 | November 26, 2020 |
