One query only without beam refinement option for FR1 ie CSI reference signal beams not there then can we say intra cell beam switching always between ssb beams.
Even I never seen any parameter like report quantity where we can configured cri rsrp or ssb index rsrp in 5g parameter
Only parameter where we can enable or disable beam refinement there ie nrtbeamrefinement true or false
My understanding this parameter only judge refined beam ie CSI-RS beam there or not.
We have CSI-RS based channel measurement ie ssb rsrp for L1 measurement indicates same if its ask to measure.
Then RE occupy by CSI-RS will measure along with secondary synchronization signal.
I also saw like 5 reports for different purposes, some based on ssb reorting, some based on CSI-RS reporting.
They are all 5 reported in uplink for various purposes.
The approach is different in FR1 and FR2.
mm wave have a different beam management.
For example in mmwave there are not less than 64 CSI-RS beams.
It is a nightmare to read the rrc connection reconfiguration message for it.
And again: everything is vendor dependent and could be much confusion reading several vendors in the same time.
As per my understanding beam refinement only valid for FR1.
For FR2 as of now 32 ssb beam only.
In FR1 each ssb consist of 4 CSI-RS beam if beam refinement enabled.
No such concept for FR2.
So from given report quantity different options one thing can be concluded cri rsrp measurement only there for L1 rsrp if beam refinement enabled.
So without beam refinement no switching between CSI-RS beams no cri rsrp.
Point is that cri exists without beam refinement as well but for cri rsrp we need beam refinement to true
As CSI-RS reference signal positions are there in slot above ssb which is linked with cri.
