Beamforming Weights Types in 5G
:small_blue_diamond:Beamforming weights in 5G can be categorized into two main types: Static Weights and Dynamic Weights, each serving different purposes across various physical channels
:small_blue_diamond:Static Weights: These are pre-configured weights used for channels that do not require frequent updates or adaptation to channel conditions. They are typically applied to broadcast and control channels
:small_blue_diamond:Broadcast Channels (Static Weights):
  • SSB (Synchronization Signal Block): Uses static beamforming weights to ensure wide coverage and reliable synchronization for initial access
  • These weights are designed to cover a broad area without frequent adjustments
:small_blue_diamond:Control Channels (Static Weights):
  • PDCCH (Physical Downlink Control Channel): Employs static weights to reliably transmit control information such as scheduling grants
:small_blue_diamond:PUCCH (Physical Uplink Control Channel): Similarly uses static weights for uplink control signaling, ensuring consistent performance
:small_blue_diamond:CSI-RS (Channel State Information Reference Signal): Static weights are used for CSI-RS to measure channel quality and provide feedback for dynamic beamforming adjustments
:small_blue_diamond:TRS (Tracking Reference Signal): Static weights are applied to TRS to maintain tracking and synchronization with minimal overhead
:small_blue_diamond:Dynamic Weights: These weights are adaptive and change based on channel measurements and feedback, optimizing performance for data channels
:small_blue_diamond:PDSCH (Physical Downlink Shared Channel): Dynamic beamforming weights are used to enhance downlink data transmission efficiency. These weights can be PMI (Precoding Matrix Indicator)-based or SRS (Sounding Reference Signal)-based
:small_blue_diamond:PUSCH (Physical Uplink Shared Channel): Similar to PDSCH, PUSCH employs dynamic weights to optimize uplink data transmission. The weights can also be PMI-based or SRS-based
